CTI dialling behaviour hardcoded in v14 SP1 Client- make it configurable
Discussion in 'Ideas' started by BarneyC, Oct 29, 2015.
  1. BarneyC
    Oct 29, 2015
    CTI dialling in v14SP1 does not work as it did in v14 Client if not on an RFC 1918 LAN. i.e having a LAN address in the following ranges:
    10.0.0.0 - 10.255.255.255,
    172.16.0.0 - 172.31.255.255,
    192.168.0.0 - 192.168.255.255
    If not in the above ranges all that happens is makecall gets sent to the phone.
    I would like to request that the restriction to RFC1918 networks is removed and/or be made configurable to include other ranges.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,968
    181
    Without knowing your motives I tend to disagree with this.
    Why would someone not follow RFC1918?
  3. AlexHeylin
    Nov 30, 2015
    44
    9
    I can give you one real life example. A client that for legacy reasons uses internet IPs on their internal LAN. Don't ask why in this instance cos I can't tell you - but they do, and they need it to work. Pls also remember that this is how the Internet used to work. I used to work for somewhere that had 2 x /16 of real Internet routable and used it for everything on their internal networks because that's how the Internet was designed. Make current config the default by all means, but allow override.
