CTI for Mac
Discussion in '3CX Clients' started by nobody, Feb 28, 2018.
  1. nobody
    nobody New Member
    Aug 15, 2017
    151
    6
    Continuing this post:
    https://www.3cx.com/community/threads/cti-for-mac.39127/
    If you want CTI for Mac (I tested snom and yealink, but many other phones are supported), look at dialectic dialer.
    Works from browser (safari plugin) and also with any "tel:" link in any browser and supports the mac address book. Can also be used to notify you on an incoming call including reverse search using the mac Addressbook.
    It needs manual configuration on every client, so, nothing for a rollout with 100phones, but works reliable for a set of a few Macs.
    IMO much better integrated in Macos then the 3CX Browser interface.
  2. Sean Glasspool
    Dec 7, 2017
    40
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    These guys?
    Code:
    We are rebuilding.
    We have the technology. We have the capability.
    Our applications will be better than they were before.
    Better. Stronger. Faster.
    In the meantime, we are temporarily halting
    the distribution & sale of all our products.
    We’ll be back soon. Thanks for your patience.
  4. nobody
    nobody New Member
    Aug 15, 2017
    151
    6
