CTI for soft phones
Discussion in 'Ideas' started by stefbeking, Nov 26, 2015.
  1. stefbeking
    Nov 26, 2015
    We would love an option where we can use the 3CX phone for windows in conjunction with soft phones.
    For example, use the 3CX phone for windows in CTI mode to controll another 3CX phone for windows on a different machine. This would work well in a terminal server enviroment for example.
    The option to controll the smartphone app would also be great. This way you can connect a bluetooth headset to your smartphone and use the 3CX phone for windows in CTI mode to controll your smartphone app. It will allow you to use your smartphone with a headset without having to take your physical phone out of your pocket.
    Regards,
    Stef
