Solved CTI Mode by Default
Discussion in 'Windows' started by interactive9, Jan 11, 2017.
  1. interactive9
    Oct 26, 2015
    22
    Hello, is it possible to set 3CX Client for Windows to open in CTI mode by default?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    14
    Go to management console > Extensions > Edit extension > Phone Provisioning
    Under "Your Phones" section choose 3CX Client and then under Preferences "Call Control:" there are 2 options -- Softphone and IP Phone.
  3. interactive9
    Oct 26, 2015
    22
    Perfect, thanks.
    Pawel_C2 and Marios Neophytou like this.
