CTI mode for N510 IP PRO
Discussion in 'Windows' started by Pastis, May 28, 2015.
  1. Pastis
    Apr 16, 2015
    7
    does the N510 IP PRO support CTI mode or not ?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    When 3CXPhone is in CTI mode, HTTP commands are send directly to the IP phone that is registered to the extension, so if the N510 “understand” these HTTP commands then it support CTI mode.
  3. Pastis
    Apr 16, 2015
    7
    ok it works now, it was a problem with the web api etc..
    thank you
