CTI Not working
Discussion in '3CX Phone System - General' started by kmanson, Sep 6, 2013.
  1. kmanson
    Sep 26, 2012
    8
    Cannot dial in CTI mode on a yealink T-28P version 2.7.0.140. I dial the number and the call button does nothing. I read that this doesn't work outside the local LAN. We have our 3CX hosted on a different subnet in a colocation datacenter.
    Any ideas?
  2. StefanW
    Jun 2, 2009
    1,199
    79
    this is not correct.
    the 3cxphone sends the cti commands to the iphones. so it will work in a remote network.
    however i have the feeling ur Firmware on the YL is to old.
    use the new 3cx fw update function to perform an update to the version needed in order to work in cti
  3. kmanson
    Sep 26, 2012
    8
    Can't upgrade the phone from 3CX, choose, upgrade firmware, check Yealink T28 2.70.0.168, click upgrade,
    , click finish, phone reboots and stays on 2.70.0.140.
    Updating model Yealink T28
    Downloading 2.70.0.168.rom
    Local file is up to date (delete it manually if you want to re-download it)
    Applying new firmware for the phone of extension 130
    Sending SIP notify to the device with MAC=00asdfEE
    Click Finish. Your phone will reboot automatically and upgrade the firmware.
    So i did a manual upgrade to 2.70.0.168 from the webinterface, and have captured an error below with wireshark.
    From Wireshark when trying to dial a number via CTI.
    Source:deskphone, Destination:pC
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML> <HEAD> <TITLE>Yealink</TITLE> <META http-equiv=Content-Type content="text/html; charset=utf-8"> <META http-equiv=Pragma content=no-cache> </HEAD> <BODY> <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0> <TBODY> <TR> <TD vAlign="top"> <FORM method="post"> <TR><TD></TD><TD class="normalText"><B> You are not authorized to access the web interface.</B></TD></TR> <TR><TD></TD><TD><SPAN class=pageInfoText><br><br> Please contact your support team or try again 3 minutes later. <br><br><hr><br><br>HTTP 401<br><br> </SPAN></TD></TR> </FORM> </TD> </TR> </TBODY> </TABLE> </BODY></HTML>
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,969
    182
    check the allowed IP of remote control and set to ANY or the IP the request is coming from.
    features.action_uri_limit_ip = %%pbx_ip%%
    this is in the v70 template for the T38. I would expect similar for the T2x ?
  5. kmanson
    Sep 26, 2012
    8
    Thanks craigreilly, phone was using an older template so those entries were missing, upgraded the template to the X.70 version and everything is working. :D
