CTI + Outlook "call contact with 3CX"
Discussion in 'Windows' started by Futureweb, Nov 3, 2015.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    Hey there,
    we are using 3CX Client in CTI Mode. 0 is needed to get external Line. But within Outlook Addressbook the Numbers have no 0 for external Line - can I tell the 3CX Software to add it when calling out of Outlook Addressbook? "call contact with 3CX" seems to ignore Phone Settings of Windows?!?
    Thank you
    Andreas Schnederle-Wagner
  2. abt1
    Oct 14, 2015
    8
    The only way i know is to use the correct format in Outlook.
    Microsoft uses the canonical format for TAPI in Outlook e.g. +49 (12345) 7654321
    In "Phone and Modem Options" you have to pick your location and fill in youre area code.
    Now you have to specify the number to access an outsideline for local and long-distance calls, in youre case 0.
    But keep in mind every number must have the canonical format.
    regards
    Klaus
  3. lauks
    Dec 2, 2015
    I have a similar problem no real solution. Using the Windows TAPI driver all works correctly in Outlook 2016 with 3CX add-on (V14). All phone numbers are saved in E164 (+ for international and brackets for area).
    But when using the 3CX tab and the 3cx buttons, + is not replaced by 00 and the country code is dialed as a number. Do I have to create an outbound rule for the plug-in but not for the TAPI? strange. Any solution would much be appreciated
    Herumakilo likes this.
