- Joined
- May 14, 2010
- Messages
- 22
- Reaction score
- 0
We recently upgraded a large install of about 70 T38 phones with 3CX from version 11 to V12. The new 3CX Windows Phone is not activating CTI on the phones. We updated the phones to the most current 3CX supported firmware (38.70.0.221). When we try to use CTI the softphone does nothing and the phone also does nothing.
However, if we change the "Trusted Action URI Server List" from "any" to the IP address of the desktop computer the phone will prompt for control, but if we reboot the phone or re-provision the phone it will no longer function and will not prompt for control. We have our provisioning file set for "any" under the "features.action_uri_limit_ip = " setting.
We have a couple of questions about this issue:
1. CTI will not function with “any” defined in the URL field.
2. Is there a timeout for the phone confirmation for control?
3. If the confirmation is missed will it come back?
4. Will the confirmation need to be done every time the phone is rebooted, re-provisioned, or firmware updates?
We are wondering if there are any other settings that we should change in the 3CX system to enable the CTI to work. We have other installations using different Yealink phones and the CTI is working properly.
We do have the 3CX Phone For Windows set to use CTI. The computers running the 3CX Phone For Windows are running Windows 7 and are on the same local network as the phones. Many of the computers are plugged into the one port switch on the back of the phones.
Thank You,
Nepal
Thank You,
Nepal
