Current Calls + Extensions in use
Discussion in '3CX Phone System - General' started by ucs1, Jul 7, 2016.
  1. ucs1
    Jun 21, 2013
    42
    Could you please keep a view in the Management Console so we can see what extensions (or system extensions) are in use / on calls and the ability to disconnect these.
    I had to restart services yesterday to drop an active call that was basically "in limbo" No one on the phone, and hard to tell that there is a current call if you don't look carefully.
  2. pact
    pact New Member
    Dec 16, 2009
    204
    37
    Yes, + show the Trunks and what calls are going over them.
    We have multiple SIP trunks and diagnosing issues can be done much quicker if we can see what line they have come in over.
    Possibly enable the ability to click on 'Current Calls' and it takes you to a Trunk Status page showing you the status.
  3. CBUTLER
    May 11, 2015
    52
    That would save some headaches when trying to find stranded calls. Right now I restart the services as you mentioned but it would be great to see those active calls with the trunk they are associated with.
  4. golden123
    Jun 21, 2016
    7
    I think the system has been made a lot harder to support with the lack of this.
  5. cylosoft
    Sep 9, 2010
    13
    I leave this screen running all the time. Badly missed. Hard to troubleshoot the first v15 install without it.
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Dont worry coming in the next update.
  7. tse
    tse
    Oct 17, 2012
    Michael, when will this update be coming? This is sorely missed...
  8. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Dont worry its coming very soon, anyway use 3CX Phone to see active calls.
  9. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
  10. cylosoft
    Sep 9, 2010
    13
    Any update on this?
  11. cylosoft
    Sep 9, 2010
    13
    Any updates?
