Current stability of software?
Discussion in '3CX Phone System - General' started by sbussinger, Mar 24, 2007.
  1. sbussinger
    Mar 24, 2007
    7
    What's the current stability of the software? Is it ready for use in a "real" environment? I'm not worried so much about small quirks in the management stuff as I am in the stability of routing calls and voicemail. I'd really like to replace an Asterisk PBX we're currently using (and having trouble with) and I'm wondering if 3CX is ready for real use yet.
    We've got 6 PSTN lines about 8 extensions handling a couple of hundred calls a day. Obviously I'll be doing some testing, but I'd like to hear from someone that's already using it if possible.
    Thanks for your comments!
  2. Anonymous
    Anonymous Guest
    THe version 3.0 seems to be stable. It is working for me and we use it 24x7.
    Mind you this is in a "home" environment.
    I am very happy with it and prefer it above astrix.
    Henk.
