Currently supported doorphones?
Discussion in '3CX Phone System - General' started by Roberto Etcheverry, Mar 13, 2018.
  1. Roberto Etcheverry
    Mar 13, 2018
    11
    I'm looking for doorphones and I've hit a snag. Since we live in LA it's kinda hard to import all the way from the EU and most of the distributors we know of don't carry Alphatech. The fanvil i20/i21 seems to be EoL'ed, is the i30 supported? Any recommendation on the video-doorphone front?
    Thanks in advance!
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    We are using 2N products without any issues - https://www.2n.cz/en_GB/contacts
    Main unit 2N® IP Verso https://www.2n.cz/en_GB/products/ip-access-control , then you add extra modules - IP Access Contrpl units
    know it is not supported, you just manually config the sip details within the device. When you setup the device, it will dial an extension or group and allow you to enter dtmf codes to open the door.
    #2 Saqqara, Mar 13, 2018
  3. eddv123
    eddv123 Active Member
    Aug 15, 2017
    905
    137
    Hi Roberto,
    See here, 3CX now list the supported door phone models:
    https://www.3cx.com/sip-phones/
    See "Supported Infrastructure Devices (Doorphones/ PA Systems/ Intercom)". Personally I would always recommend acquiring a supported product for peace of mind.
    #3 eddv123, Mar 13, 2018
  4. Roberto Etcheverry
    Mar 13, 2018
    11
  5. eddv123
    Aug 15, 2017
    905
    137
    Alphatech in the UK are also called Moshi door entry systems - it maybe that you need to search for that name.
    Cyberdata are distributed by 888 VoIP and many other distributors in the U.S it would seem:
    http://www.cyberdata.net/support/voip/ordervoip.html
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    281
    Please note that the tested and supported devices by us are the ones listed in our website. I can see however that Fanvil has 3CX listed as a compatible system for the i30, but if you face any issues you will need to speak to Fanvil. Generally speaking as this is a SIP device it should work with the PBX.
  7. Saqqara
    Mar 12, 2014
    872
    133
    Have to agree with YiannishH_3CX, if the device is a SIP device it should work.
    Really do not need templates to configure these devices, just manually add the sip details to the unit (probably via web front end)
