Custom#1 & Custom#2 Status**DISCUSSION FEAT REQUEST
Discussion in '3CX Phone System - General' started by PaulD, Jul 25, 2010.
  1. PaulD
    Jul 4, 2010
    90
    11
    Can anyone tell me whether it is possible to rename the terms 'Custom#1' and 'Custom#2'? We are an educational user and would find it helpful to rename 'Custom#1' to 'Teaching' for example. This would be more friendly and indicative than using the generic 'Away' status.
    Many thanks
  2. carolinainnovative
    May 4, 2009
    369
    6
    Re: Custom#1 & Custom#2 Status**Discussion
    Not currently - but it has been requested.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi , yes this can be done. Just go to 3CX folder > Data > Http > Includes and edit the language file for Management and Myphone.
    Just Find all words related to Custom1 and Replace with whatever text you want.
    The same must be done for Custom2. Also a restart of the Phone system is required and done.
    Thanks and Regards.
  4. PaulD
    Jul 4, 2010
    90
    11
    Many thanks. Presumably, I'll need to repeat the exercise with each 3CX version update?
    Paul
  5. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Yes, this can be done for the Call Assistant too. You can change this by going - C:\Users\Michael\AppData\Roaming\3CX Assistant\data and edit the language file.
    Thanks and Regards
  6. PaulD
    Jul 4, 2010
    90
    11
    OK. The fact that it can be done at all is most useful. Have you considered including these terms within the user definable 'Custom Parameters' variables section?
    Many thanks
  7. carolinainnovative
    May 4, 2009
    369
    6
    well darn - I thought I read it couldn't be done.
    Any way we can get this in the GUI - maybe something the assistant downloads from 3cx instead of having to edit it on each client?
  8. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Just change it from the language file. We have more important things to worry about at the moment. You can also explain to your users that CUSTOM1 = TEACHING. or modify the language files and keep a backup of them. You can change the ones of the assistant too. Then get all the language files and take a backup of them before you uninstall. Then we will see what we can do later.
  9. PaulD
    Jul 4, 2010
    90
    11
    Agreed and I will do just that. I'll need to automate the client side file update because we have a lot of machines. This is an acceptable approach in the short term but I will manually reapply the changes with each version release since the solution you advise risks losing 3CX new additions to the language files.
    I fully understand the need to prioritise tasks. Is there any chance of adding this to a low priority wishlist?
    Many thanks and keep up the good work.
  10. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Hi - All you need to do is change 2 entries in local language files of the server.
    Myphone and management resources are here
    C:\ProgramData\3CX\Data\Http\includes
    Then with the assistant you can distribute any language file updates you need by modifying the zip file
    location
    C:\ProgramData\3CX\Data\Http\Interface\AssistantStore\tcx.assistant.client.zip
    Folder ClientUpdates_data_initdata - change them there for the clients. Clients will update and entries will be changed.
    Yes we will add something like this in the future.
    The English language file is not going to change so much.
  11. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Ok post this in feature request forums.
  12. PaulD
    Jul 4, 2010
    90
    11
    Sorry, I'm new to these forums. As Site Admin, can you move the whole thread or do I need to reproduce it?
    Cheers
