Custom Caller ID
new4
Hi, to all :)
I have read various posts about caller ID issues with
3cx, e.g http://www.voipstore.com/how-to-set-3cx-caller-id/
I have a question though.. Is it possible to set a
custom caller ID for a PSTN line which is connected
to 3cx through a Linksys SPA3102 pstn to voip gateway??
If so, how can this be implemented? I'm still using
ver. 8
Any help will be greatly appreciated!
Thank you in advance for your attention,
Vassilis
Rhodes island-Greece
No, unfortunately. On PSTN lines, as with GSM gateways, the outgoing caller ID is determined by your provider, only they can change it. You can, on outgoing VoIP lines, if the provider allows it.
Thank you! Please check your P.M
Get 3CX - Absolutely Free!
3CX
