Custom code component feature
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 6, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Setting the object type and method name via a variable would be a nice option to have.
    It would save a lot of routing logic in some workflows.
    Especially since there is a limit to the number of nested calls at runtime, the more that can be done via a variable (and not lots of components) the better.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Thanks again for your suggestions. They'll be considered for the next version we're working on...
