Solved Custom config file doesn't respect "SP1"
Discussion in '3CX Phone System - General' started by engin411, Mar 6, 2017.
  1. engin411
    engin411 New Member
    Jul 3, 2009
    172
    3cx latest version with Yealink T46G phones, latest firmware. I'm editing the default Yealink template to include some features we use, specifically shared park. Below is my values/etc for this, and while the buttons show on the phone, the shared parks show as unregistered and they don't work. Pressing a shared park button during a call does nothing.
    Ideas? Here's what I'm using in the custom template:
    linekey.6.line = 0
    linekey.6.value = SP1
    linekey.6.pickup_value =
    linekey.6.type = 10
    linekey.6.label = Park 11
    linekey.6.extension =
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    I thought the lines were now not ZERO based.
    Perhaps try that..
    Here is mine:
    Code:
    linekey.14.type = 10
    linekey.14.value = SP3
    linekey.14.line = 1
    linekey.14.label = SP 3
    linekey.14.xml_phonebook = 0
    engin411 likes this.
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Yes line must be 1 not 0.
    The best way when in doubt is to have 3CX create a provisioning file for an extension with some Shared Parks and then look at the file that is created (you will have to browse in v15 as the files don't go in the provisioning folder).
  4. engin411
    engin411 New Member
    Jul 3, 2009
    172
    That was it, shared parks are working now, thanks guys!
