Custom Development Script
Discussion in '3CX Phone System - General' started by chris.chappel, Jun 5, 2013.
  1. chris.chappel
    Jun 5, 2013
    We have multiple implementations of the 3CX Phone System 11 on x64, but for one specific instance in which we have implemented a windows service that makes a call to the Config Server, so that we can add an extension to a ring group for a time and then remove it. The service runs well for 2 weeks, then the 3CX Config server no longer becomes accessible. We get this error, “TCX.Configuration.Exceptions.PhoneSystemException: Config server is not connected”. The only fix for this is to restart the Config Server, which restarts all of the services. After restarting the Config Server, it is accessible again. Any thoughts?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    You can create a script which will restart 3cx services once a week :lol:
  3. chris.chappel
    Jun 5, 2013
    We are trying to stay away from having to do such a thing.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If PBX continue to work then you need to verify implementation of your service.
    If PBX stopped to work then please report the issue
  5. chris.chappel
    Jun 5, 2013
    The PBX continues to work for the most part.
    The config server is what becomes unresponsive. We are opening a ticket to see what the issue here might be.
    We've implemented the script using the same format as the examples that were provided with the API.
    If I provide the function, would that help?
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    Please provide reference to the ticket.
