Custom directory settings in Yealink.ph
Discussion in '3CX Phone System - General' started by johandezwaan, Jun 10, 2014.
  1. johandezwaan
    Nov 13, 2013
    14
    we are using the 3CX V11 software with a lot of Yealink T26 and T28 phones on the V72 firmware.
    My problem is that when we update the custom yealink configuration files the system overwrites the configuration files after a while.
    The custom configuration files we are editing are y000000000000.cfg and y000000000004.cfg
    The lines we want to add are
    directory_setting.url = http://PBX IP:5000/provisioning/Directory_setting.xml
    super_search.url = http://PBX IP:5000/provisioning/super_search.xml
    How can we add those lines to the Yealink.PH files so that the system also rebuilds the configuration files containing our lines?
    Kind Regards.
    Johan de Zwaan
  2. johandezwaan
    Nov 13, 2013
    14
    After some more searching i found the settings in an YealinkT4x.ph.xml file.
    after copying those lines the system rebuilds the config files as desired.
    i added the following lines to the XML.
    Code:
    ##                                   Super Search URL                                ##
    super_search.url = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/super_search.xml
    Code:
    #Configure the access URL of the directory setting file.
    directory_setting.url = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/Directory_setting.xml
