Custom GUI
Discussion in '3CX Phone System - General' started by Rodeo, Jul 14, 2012.
  1. Rodeo
    Jul 13, 2012
    6
    I want to know if 3CX provides some kind of tool or functionality to design an external GUI. My idea is to have 3CX in one PC and in another my custom GUI talking to 3CX.
    Thanks in advance
    Rodeo
  2. wagner.damiao
    Jul 6, 2012
    17
    To help you better for what purpose we will use the GUI?
    By default, 3CX offers integration with:
    Salesforce
    Microsoft Dynamics
    SugarCRM
    Sage Act!
    Google Contacts
    Regards!
  3. Rodeo
    Jul 13, 2012
    6
    Thanks Wagner,
    Basically my project consists in 3 parts: The PBX server (3CX Phone System: administrative purpose), terminals (3CX Phone Android: smartphones with WiFi connectivity) and Main application (Custom GUI: smartphones or tablets).
    The Custom GUI is basically an application with buttons, no more, to select specific terminals under a paging group. I was thinking to design the GUI with Adobe Flash and talk to the PBX using something like PHP. We can see the Custom GUI like a soft client installed in a smartphone or tablet. Its job is to select/talk the paging groups.
    Thanks in advance for your answer
    Rodeo
