Solved Custom logo for Yealink T48G
Discussion in '3CX Phone System - General' started by MarkTTU, Feb 24, 2017.
  1. MarkTTU
    Feb 21, 2017
    6
    I'm new to the 3CX world and the Yealink world as well (coming from Cudatel and Polycom 335). I've dug around enough in the templates to find there are logo files being loaded to the phones, but I'm at a loss on how I'd change it to my custom logo.
    Where on the server would I put the logo file?
    What size does the logo need to be?
    After seeing this:
    wallpaper_upload.url = %%PROVLINKLOCAL%%/logo/yealinkt48.png
    screensaver.upload_url= %%PROVLINKLOCAL%%/logo/yealinkt48.png
    I thought I'd be able to find the logos and do my own digging from there, but I can't find those PNGs on my server to save my life.
    Any assistance would be much appreciated.
  2. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Size is 800x480.
    MarkTTU likes this.
  3. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    On my Server I find it here:
    C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\...\logo
    Just use the windows search-feature...
    and make C:\programdata VISIBLE
    MarkTTU likes this.
  4. MarkTTU
    Feb 21, 2017
    6
    I can't find anything similar to that; no http folder at all. Are you on v15?
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    I can confirm, on 3cx Server, that is the folder I use.
  6. MarkTTU
    Feb 21, 2017
    6
    What version of 3CX?
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Its the same on pretty much all versions. Make sure that you follow the path correctly. It's in Program Data under Instance1
  8. MarkTTU
    Feb 21, 2017
    6
    Sorry guys, id-10-t error. Kept reading program data as program files... guess that's what I get for being up too late trying to do too many things at the same time. All is well now and I really appreciate the assistance!
  9. Milton Schreiber
    Dec 31, 2016
    18
    How would I go about changing the logo files on a Debian Linux install on the Google Cloud? Can I just replace yealinkt48.png with my own logo file and rename it to yealinkt48.png without changing the proviosioning template?
  10. YiannisH_3CX
    May 10, 2016
    6,016
    420
    Hello @Milton Schreiber
    In theory it should work although i haven't tested it. Just make sure that you keep the original in case something goes wrong and your image is the correct format and dimensions.
