Custom Logos for Yealink T46G
Discussion in '3CX Phone System - General' started by IT Hamster, Jun 1, 2015.
  1. IT Hamster
    May 21, 2015
    43
    Hello all,
    I've been digging through this website and google for a guide on how to get custom logos on the displays of my T46G phones (and other Yealink models) and all of the articles are a good 5 years old and all of their links are pointed to 404 errors now days.
    Is there a current guide on how to upload and provision custom logos for Yealink phones through 3CX V12?
    Thanks,
    IT Hamster
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    It is in the 3cx Template for that line of phones:
    wallpaper_upload.url = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/%%PROVSUBDIR%%/logo/yealinkt46.png
    Just do a search for that filename and you will find the directory buried in C:\ProgramData folder.
    (I do recall in the past a second line was required to upload or select that file... but do not have any Yealinks on my current setup)
  3. IT Hamster
    May 21, 2015
    43
    Thanks Craig! I took a look at that and that seems to be what I need to get after, I'll post again once I can confirm the process.
    I think the second line for editing is the following (just gotta make sure the filenames match your files):
    #Configure the phone background.
    #If you set the custom image (new.png) as phone backgroup, the value is: phone_setting.backgrounds = Config:new.png
    #If you set the system image (pictures(01).png) as phone backgroup, the value is: phone_setting.backgrounds = Resource:pictures(01).png
    {IF ua=SIP-T46G}
    {ENDIF}
  4. engin411
    engin411 New Member
    Jul 3, 2009
    172
    I worked on this today too on v14, and found the proper setting in this section in the provisioning file: ## Configure the access URL of the Wallpaper and Screensaver ##
    Edit. Seems like I need to change the file name in both places in the provisioning file, not just in this Access URL section.
