Custom Outbound sip header
Discussion in '3CX Phone System - General' started by rkodas, May 14, 2015.
  1. rkodas
    May 14, 2015
    Is it possible to add custom field to SIP header? I need to add field "X-Fid" with OutboundCallerId value.
    In asterisk I had:
    "exten => _X.,1,SIPAddHeader(X-Fid: ${SIPCALLID})"
    How to do it in 3CX (ver 12.5).
    Regards,
    Robert
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Unfortunately you can't add such field, there is a predefined list of fields which can be set through your voip provider settings / Outbound Parameters tab.
