Custom Paging Alert for anouncements
Discussion in '3CX Phone System - General' started by wes1007, Aug 15, 2013.
  1. wes1007
    Aug 15, 2013
    16
    Hi everyone,
    I have set up a simple PA system on a premise and i am wanting to know if it is at all possible to play a sound at the beginning of the call to alert people that an announcement is being made.
    I have 4 Snom PA1s in a group but would also like for the alert to work when calling each device individually.
    Had a quick look around and I don't see anywhere to enable / customize this... any help would be appreciated
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    209
    Announcements are generally done with multicast or intercom -
    I do not have experience with all handsets but usually these both produce a tone.
    An intercom call from one extension to another should result in a tone as well.
    Is this what you are after?
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    In addition to Craig's thoughts -
    You might do what many have done for years:
    Set up the page and then when you are reasonably sure that the connections are established, press any of the phone's buttons to generate a DTMF tone(s).
    You can press as many or as few as you like and it doesn't get any more custom than that.
    This used to be a fairly standard practice of old, not so much to pre-announce to the intended audience, but more so to confirm to the initiator that the system was up and ready.
  4. wes1007
    Aug 15, 2013
    16
    Thanks guys!
    The PA1 does have a tone that plays but i've played around with reconfiguring it and its just not loud enough when compared to the volume of the announcers voice.
    Going to try a custom ringtone on it and somehow get it to auto answer after it rings once.
