Solved Custom Phone Provisioning?
Discussion in '3CX Phone System - General' started by JST, Jan 9, 2017.
  1. JST
    JST New Member
    Jan 8, 2017
    107
    Is it possible to create a custom phone provisioning file? For example, I see that you are supporting the Cisco 7961, but not the Cisco 7975G. I believe it should pretty much work with the same file. The only difference would be some extra buttons on the Cisco 7975G which could be added manually.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,178
    184
  3. JST
    JST New Member
    Jan 8, 2017
    107
    Your solution is for V14, but I was able to find it under Settings -> Templates in V15 as well. Not sure how I missed it...
    Thank you! :)
  4. cobaltit
    Mar 22, 2012
    1,178
    184
    Yeah.. some of the template paths are off in the articles, but your question was more of a generic 'can you'. The other problem you will likely run into with regards to the Cisco phones are that you technically need active SmartNet to get the SIP firmware for the phones (typically they are running SCCP firmwares, and that Cisco very poorly documents the process for provisioning their phones under SIP.
    Good luck!
  5. JST
    JST New Member
    Jan 8, 2017
    107
    Thank you!
    I just played around with the template functionality and copied the Gigaset N510 to a custom Gigaset C610A. It somewhat worked, but I am not sure what the process is for multiple extensions. I was able to provision the phone to one extension, but when I try it for a second extension (the base station supports up to 6 handsets), it doesn't allow me to do so because the MAC address is already assigned.
    Maybe somebody got this running on a Gigaset N510 which is supported?
    Yeah. I figured I would face more issues with a Cisco phone...
  6. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Additional extensions cannot be
    provisioned and must be created manually inside of the base station.
  7. JST
    JST New Member
    Jan 8, 2017
    107
    Thank you! That makes sense. It seems to work. :)
  8. Hector Rodriguez
    Jan 10, 2017
    I have a quick question, I've tried to edit one of the templates on v15 but it looks like it does not take the changes, it's for the yealinkT4x.ph.xml file, I checked the link posted above (which BTWis for v14) and I'm unable to make any changes on the file, it's like if I don't have permission, am I doing something wrong?
    thanks in advance for the help.
  9. JST
    JST New Member
    Jan 8, 2017
    107
    Did you press the save button? The UI is somewhat confusing for templates because you have a big OK button on top (similar to all other configuration menus) and then there is a smaller Save button (next to the copy button) further down. If you only press OK, it doesn't save.
    I did the same thing... ;)
  10. Hector Rodriguez
    Jan 10, 2017
    Hi, my apologies, maybe I needed to post a little bit more info, just to explain my scenario, I have over 50 Yealink T22P IP phones connected through my 3CX V15 management console, I see the "templates" section under settings, I do see the template yealink.ph.xml, but it seems to be in a read-only mode, I'm unable to edit it, I can't neither cut nor paste either.
    I want to set the parameter on the line 1672: "phone_setting.lcd_logo.mode" to 0 so that the IP LCD will stop switching between the 3CX logo and the time stamp (image attached) but it does not let me change anything on the original file.
    Another thing I did as a walk-around is I created a copy of that yealink file (which I was perfectly able to edit) but now I looks like I need to go through each one of the phones and load that new customized file in order for the phones to take the changes, is there any other most-efficient way to get this done to be able to edit this parameter and update all of the phones simultaneously?
    I hope I made myself clear, but if any additional information is required just let me know and I can post it here.
  11. JST
    JST New Member
    Jan 8, 2017
    107
    I don't think it is possible to change the original template. I believe that's why they have added the function to copy an existing template. I also haven't seen any mass processing capabilities. Maybe 3CX support would know? Sorry, but I am new to 3CX myself.
  12. Hector Rodriguez
    Jan 10, 2017
    Hi thank you for your response, I've been playing with the options all day long and I finally found the solution (I think), the template .xml file can be edited from its location, you can find it under settings > parameters > PROVISIONING_FOLDER_ROOT (it's something like this C:\ProgramData\3CX\Instance1\Data\Http\Templates\phones) here you can edit the files using admin permissions with an editor such as Sublime or Notepad ++, just make sure after making the changes you restart the services, it worked for me and after changing the source file code, you just need to re-provision the phones, thank you so much for all your guidance.
    Regards!
  13. JST
    JST New Member
    Jan 8, 2017
    107
    That's good to know. Thanks for sharing!
