CUSTOM SCRIPTS
Discussion in '3CX Phone System - General' started by markkarp, Feb 3, 2011.
  1. markkarp
    Feb 3, 2011
    Does anybody know if there is a way to create custom scripts (or macros) to control queues behaviour/response. The same question applies to extensions.
    Your response is greatly appreciated
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Can you give us an idea of what you are trying to do. Combinations of queues, ring groups, digital assistants and dummy extensions is very powerful and we have some complex set ups, so I dont think you need custom scripts.
    Post an example of what you want and I will try and do it using the available 3cx resources.
