Solved Custom SMTP Server
Discussion in '3CX Phone System - General' started by DJimenez, Feb 13, 2018.
  1. DJimenez
    Jun 10, 2015
    5
    I upgraded to the most recent version (15.5.8801.3) over the weekend. Everything works fine except email notifications. I can't use my email server only the 3CX SMTP server. Any ideas why? I have the Professional perpetual license.
  2. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
  3. DJimenez
    Jun 10, 2015
    5
  4. MichaelTC
    Jan 2, 2018
    Windows 10 Pro (15.5.8801.3) same issue also professional perpetual license.
    Using a simple custom smtp server (port 25) to our exchange 2010, upon testing the "new email settings interface" I receive the 'No compatible authentication mechanisms found'.
    3cxSystemService.log
    2018/02/14 16:29:46.208|7040|0007|Excpt|System.NotSupportedException: No compatible authentication mechanisms found.
    at MailKit.Net.Smtp.SmtpClient.Authenticate(Encoding encoding, ICredentials credentials, CancellationToken cancellationToken)
    at MailKit.MailService.Authenticate(String userName, String password, CancellationToken cancellationToken)
    at GenericUtilsNet.Mail.SmtpConnect(SmtpClient smtpClient)
    at GenericUtilsNet.Mail.Send(AlternateView calendarData)
    at _3cxSystemService.VoiceMailScanner.EmailNotif.SendMail()
    at _3cxSystemService.VoiceMailScanner.BoxesMonitor.ProcessList(List`1 list, Dictionary`2 problematicDirectories, ManualResetEvent stopEvent)
    #4 MichaelTC, Feb 14, 2018
  5. jhaney
    Feb 21, 2018
    I am seeing the same error as well. Internal Exchange 2010 server. Any update on this?
  6. StefanW
    Jun 2, 2009
    1,236
    96
    what are the configuration settings in your exchange? As this is clear: No compatible authentication mechanisms found. All offered exchange auth methods can not be used by 3CX. I personal go with IP auth for my 3CX pbx on a custom SMTP port
  7. jhaney
    Feb 21, 2018
    Disregard, got it working, thanks.
  8. StefanW
    Jun 2, 2009
    1,236
    96
    if you could share with the users of the forum your altered changes would be great
  9. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
  10. Ryan Parsons
    Jun 22, 2017
    Had this exact issue and found this forum post during my course of troubleshooting. The issue in our environment was TLS 1.2 was not enabled in the registry on the smtp server in Microsoft Server 2008 R2.
    Found the following articles:
    Enabling TLS 1.2: https://support.quovadisglobal.com/kb/a433/how-to-enable-tls-1_2-on-windows-server-2008-r2.aspx
    Also verify that SSL 2.0 and 3.0 are disabled: https://www.sslshopper.com/article-how-to-disable-ssl-2.0-in-iis-7.html
    When you are done reboot the server. Log into the 3CX console and go back to Settings -> Email and check Enable SSL/TLS. Verify the rest of your smtp server settings are correct and press the Test button.
    Verify anything else that depends on the SMTP server is functioning correctly. If the server is a WAN facing server, also hit it with this: https://www.ssllabs.com/ssltest/.
    #10 Ryan Parsons, Mar 6, 2018
