Custom Speed Dial Pause
Discussion in '3CX Phone System - General' started by JStellato, Aug 18, 2017.
  1. JStellato
    Dec 17, 2015
    33
    6
    We are hooking up a Cyberdata Paging Server. I wanted to create a single custom speed dial that could call the paging server, and then dial the page code. The problem is, the paging server waits about 2 seconds before accepting input.
    My idea was to put a pause in the custom speed dial, i.e.
    199#,,01
    Extention
    Hashtag to Dial
    Two Comma Wait
    01 Page Group
    However 3CX seems to be ignoring my commas. Am I using the wrong syntax?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,079
    202
    Did you try P
    I don't think it works... if I recall - it is not a STANDARD in the SIP.
  3. leejor
    10,567
    246
    The only way you could do it is a speed-call button on an analogue set. One that allowed a pause to be programmed.
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    A comma is a throwback to the Hayes modem instruction set. It was oftentimes used to instruct the modem to wait after the initial dial string in order to give the PBX or other system enough time for the outside line to be identified and go off-hook and even input in a charge number when calling cards were big time.
  5. leejor
    10,567
    246
    Unfortunately, in the majority of cases where a pause is desired, the type of signalling required after the pause is DTMF. This requires that the device initiating the call is capable of doing this.
  6. JStellato
    Dec 17, 2015
    33
    6
    Ok thanks, I was trying to simplify the paging to a one button configuration. I'll just bail on the multicast solution and just use the page SIP feature
