Solved Custom Speed Dial Problem
Discussion in '3CX Phone System - General' started by JST, Dec 15, 2017.
  1. JST
    JST New Member
    Jan 8, 2017
    107
    I have just connected a Yealink T46S using auto provisioning and it seems to mostly work fine except when I am trying to use one of the custom speed dial buttons. I have basically assigned my custom speed dials in the extension configuration and they seem to have made it over to the phone just fine, but when I am pressing a speed dial button, I am getting the message that the call cannot be completed.
    Oddly, enough I can dial the same number manually just fine. So, I am guessing that there is a problem in the script for the Yealink T46S.
    Did anybody get this to work? Thank you!
    10,362
    226
    It would seem that they didn't make it over the phone "just fine". After a failed call, check the 3CX Activity Log to see exactly what digits were sent to the PBX (if any). That should give you a clue as to what went wrong.
  3. JST
    JST New Member
    Jan 8, 2017
    107
    Thank you for your reply!
    I have spent some more time on this and after another reboot of the phone it works just fine.
    I am not sure why I didn't work before. Only explanation might be that I did a firmware upgrade after the original auto provisioning. Not sure...
    Anyhow, it is working now! I will keep an eye on it and report back when it stops working again.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,381
    278
    Glad to hear the issue is now resolved. Probably the firmware you were running was not matching the used template. Keep an eye on it and report back if the issue re-appears.
  5. JST
    JST New Member
    Jan 8, 2017
    107
    I will, but I think you are right about running a high enough firmware version.
