Custom Template Problem
Discussion in '3CX Phone System - General' started by TRILAN_SteveG, Sep 15, 2016.
  1. TRILAN_SteveG
    Oct 29, 2015
    9
    10
    :S Hi All,
    I am having trouble adding a 2nd EXP unit to the template for a Yealink T46G.
    No matter what I try when you select the phone and select "config" then it just comes up with an internal server error.............remove it and it all shows up ok.
    I cannot for the life of me work out where I am going wrong with this one!!!
    This is on v15 FYI.
    Any help greatly appreciated.
    Regards
    Steve
  2. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    The provisioning of the second EXP module is not supported by 3CX.
    However if you want to add second EXP module you can add a custom Template for your YealinkT46G and add the provisioning of the second EXP module.
    Here is an example of the first 2 keys of the second EXP :
    #Expansion module2 key1
    {IF blf66}
    expansion_module.2.key.1.type = %%DKtype%%
    expansion_module.2.key.1.line = %%Line%%
    expansion_module.2.key.1.value = %%blf66%%
    expansion_module.2.key.1.pickup_value = %%PickupValue%%
    expansion_module.2.key.1.label = %%blffirstname66%% %%blflastname66%%
    expansion_module.2.key.1.extension = %%PickupValue%%
    expansion_module.2.key.1.xml_phonebook =
    {ELSE}
    expansion_module.2.key.1.type = NA
    {ENDIF}
    {ENDIF}
    #Expansion module2 key2
    {IF blf67}
    expansion_module.2.key.2.type = %%DKtype%%
    expansion_module.2.key.2.line = %%Line%%
    expansion_module.2.key.2.value = %%blf67%%
    expansion_module.2.key.2.pickup_value = %%PickupValue%%
    expansion_module.2.key.2.label = %%blffirstname67%% %%blflastname67%%
    expansion_module.2.key.2.extension = %%PickupValue%%
    expansion_module.2.key.2.xml_phonebook =
    {ELSE}
    expansion_module.2.key.2.type = NA
    {ENDIF}
    {ENDIF}
  3. TRILAN_SteveG
    Oct 29, 2015
    9
    10
    Thanks for this, I only had the 2nd End IF at the very bottom of the entire list of buttons.
    I will give this a go and report back.
