Custom Template: what if... ?
Discussion in '3CX Phone System - General' started by itgs, Mar 9, 2017.
  1. itgs
    Nov 8, 2008
    57
    If I customized a template for desktop phone (Yealink), making a copy of default template binded in 3CX, what happen when there are updates in the templates ?
    I will have to modify again the new template and add all custom parameters ?
    Is there some smart way to avoid this manual procedure ?
    Thank you
  2. phil@lgmanor.com
    Oct 13, 2016
    25
    I use WINMERGE to compare the 2 files. It will find the differences, then you have the choice to copy over just the new settings you need. Take a few minutes at the most.
