Custom Template
Discussion in 'Ideas' started by auxilium, Mar 1, 2017.
  1. auxilium
    Sep 4, 2012
    I need to change the template of snom phones.
    the modified template is applied to all phones. Now I will see in the section phones Snom (Custom Template) and red text for all phones, it is not very good to see. It would make sense if I changed the template for 1 or 2 phones, but not for everyone if the template is stable and works.
    I wish it were possible:
    1) remove the words "(Custom Template)" that, in the smaller screen, forcing you to see every instance in two rows
    2) to change the color from bright red to orange or otherwise.
