Custom voice prompts
Discussion in '3CX Phone System - General' started by yaro, Nov 23, 2011.
  1. yaro
    Jun 11, 2008
    38
    Is there a way to check from the phone system what automated responses a particular user set up on their softphone as it created some confussion or do i need to check users computer for that?
    11,079
    324
    I'm not sure what softphone you are using, there may be some that can answer the call on the PC, but, in the 3CX world, the call routing and messages are handled by the PBX. You can access functions to change this from a PC, but 3CX still takes care of what happens to the call.
    What are callers actually reaching?
  3. yaro
    Jun 11, 2008
    38
    In that case if it's set to transfer to voicemail in out-of-office hours for a particular extension where do I find the file with the pre-recorded answer message?
  4. leejor
    11,079
    324
    Here is a link to a thread on message location.
    http://www.3cx.com/forums/prerecorded-voicemail-prompt-18908.html#p95803
    It's going to differ (slightly) depending on your operating system.
  5. yaro
    Jun 11, 2008
    38
    Found it. Many thanks
