Customer survey via VAD
Discussion in 'CRM / Helpdesk / App Integration' started by igor.snezhko, Feb 25, 2016.
  1. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    Hi!
    Is it possible to use VAD to make a customer survey after call completion?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,345
    108
    Hi Igor,
    Using the VAD you can create the callflow for the survey, but you need that the agent manually transfer the call to this application. Currently there is no way to forward the call automatically when the call to the agent ends. You might want to suggest that feature for 3CX here: http://www.3cx.com/ideas
    Kind regards.
