Customize alert info
Discussion in 'Ideas' started by chikara sugiyama, Dec 14, 2017.
Customize alert info 5 5 4votes
5/5, 4 votes
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hello.
    (Translated from Japanese to English by Google translation)
    I often hear from users that they want to divide the ring tone for each SIPTRUNK.
    Operation is sent from SIPTRUNK to the extension via IVR, Ringing group, ACD.
    Certainly there are alert info such as IVR and Que, but it is troublesome when setting multiple IVR and ACD.
    Ideally I would like to set alert info for IVR, Ringing group, ACD Virtual Extension Numbe.
    I think that the number of Virtual Extension Numbe is sufficient for the value of alert info.
    Do not you think it is convenient?
  2. Silly English Kniggit
    Sep 13, 2017
    220
    85
    Distinctive ring is sort of supported - but 3CX doesn't configure it properly. It's usually possible by template hacking - but it could be vastly improved. 20 year old systems we're replacing have this feature - it's embarrassing to say 3CX doesn't.
  3. J_Hermsen
    Aug 29, 2016
    15
    I'd like to be able to distinct ringtones between the different Queues with specific alert-info would be use full
