Customize to use Port 5070
garsnow
The manual states that you can create a custom port 5070 to use over port 5060 in the General Options however I cannot find this option.
How do I make this change as we have an internal 5060 conflict.
Ok the general id is that you setup a port for listening.
YOu can do this under the Gateway configuration. For each gateway you can configure what SIP port you want to use.
So this is the GATEWAY, not the PROVIDER as this most likely is depending on your VSP.
Getting Started - Admin
YBow
Get 3CX - Absolutely Free!
3CX
