Customize Yealink Configuration / Screen Saver
Discussion in '3CX Phone System - General' started by rely1, Mar 22, 2018.
  1. rely1
    Sep 14, 2011
    I have been experimenting with making changes on the Web interface of the Yealink phones that were provisioned via STUN from V15.5 3CX. Specifically changing the wallpaper or screen saver.
    Can anyone guide me in which lines to change to change the screensaver to a custom image file. How do I get the image file to the Linux version of 3CX so that the provisioning server can push the custom configuration to the phone?
    I have made a copy of the Yealink T48s configuration and was going to make changes to the copy.
    I found a section called screen saver and an element upload url, but I'm unsure where to put the file and how to tell the Yealink to upload the screen saver and not use the default 3cx screensaver.
    Thanks,
    Richard
    JWillScott likes this.
