Customized reporting
Discussion in '3CX Phone System - General' started by raj, Nov 30, 2010.
  1. raj
    raj
    Nov 30, 2010
    How can I connect to 3CX database to be able to extract data for creating my custom reports. I checked the forum and found that version 7 has ways to connect to database using odbc, but no information is available for connecting to version 8 or 9. This document explained how it worked in version 7.
    http://wiki.3cx.com/old-versions/custom-call-reporting
    I tried this approach but PostgreSQL ODBC driver will not accept username: logsreader and not even the admin password that I use for connecting to 3CX phone system. Can someone provide me information about achieving this with version 9. Thanks...
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi.
    The PAssword for the database can be found in the program files/ 3cx phonesystem folder, in a file called phonesystem.ini there you must look for a field called dbpass = SOMETHING . It will be a bunch of hashes and characters. You can use that to access the database.
  3. raj
    raj
    Nov 30, 2010
    Hi Mark,
    Thank you very much. It worked perfectly.
    Regards,
    Raj
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Raj,
    Your welcome. Best of luck with your setup.
