Customizing Phone Provisioning for 3CXPhone
Discussion in '3CX Phone System - General' started by LVJ, Dec 14, 2012.
  1. LVJ
    LVJ
    Jun 21, 2012
    I’m having problems with phone provisioning with 3CXPhone. The problem is that when I’m using provisioning then the external IP is getting the same port number as local IP in “My location” and under “Use 3XC Tunnel” the Local IP is not getting the port number?
    If I change the <PBXSipPort>zzzz</PBXSipPort> then the change is also used for the external IP?
    This is the setting I want:
    Local IP: yy.yy.yy.yy:zzzz
    External IP: xx.xx.xx.xx
    Local IP of remote PXX: yy.yy.yy.yy:zzzz
    Lasse
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Can you be more specific on that? What version of 3cx are you using? What phones are trying to provision. What is the exact option that you are using when provisioning the phones?
  3. LVJ
    LVJ
    Jun 21, 2012
    I'm using v11 sp .3 and this is for the soft client
    [​IMG]
    As you can see then the I am out of the office - external IP is getting the port number and not Local IP ao remote PBX: and that is not working.
    If I change it and remove the port nr. on I am out of the office - external IP and add it to Local IP ao remote PBX:, then it works
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    For the out of office settings and using the tunnel, you don't need the port - just the external IP. In the tunnel section, you will need to specify the local (lan) ip and port of the 3cx PBX. The tunnel will look after the rest, so long as you have the tunnel port matching on both ends.
