*CX VoIP Client crashes
Discussion in 'Windows' started by sipbybb, Mar 28, 2008.
  1. sipbybb
    Mar 28, 2008
    The 3CX VoIP Client crashes everytime shortly after it has been started, except the very first time after installation (System WinXP SP2, happens on different computers). A reboot of the system doesn't help. What's the reason for that?
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Hmm, well many people here are got it installed on XP, Vista, 2K3, and no problems.
    It suggests something many wrong with your computer - maybe try the software on another computer to see if it works. If it does then it must be you computer, and a fresh install maybe needed, or restore an old backup point?
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    If you are 3cx starting what do you see in de services??? you can also try to stop 3cx to start automatically with Windows.
