D-Link DFL-300 Firewall
Discussion in '3CX Phone System - General' started by hollyb, Jul 30, 2011.
  1. hollyb
    Jul 30, 2011
    6
    I am wondering if anyone has successfully gotten a D-LINK DFL-300 Firewall to work with 3CX.
    We have 3CX version 10 with a Sangoma A200 gateway.
    Everything internally works fine. We are having trouble with External extensions. There is no sound. These phones are Grandstream GXP1450 phones that we provisioned in the office and then taken off site. We changed the private IPs to the Public IPs. This to me is a problem with the ports on our firewall but I have checked and double checked as well as had another engineer look and do not see a problem.
    The external phone dials, rings 2 times and appears to go to voice mail for the extension it called. We also have the same problem with our external Bria softphone users.
    Here is the server log.
    13:05:17.562 Currently active calls - 1: [6]
    13:05:10.359 [CM503007]: Call(6): Device joined: sip:999@127.0.0.1:40600;rinstance=62c55bcabdc42122
    13:05:10.359 [CM503007]: Call(6): Device joined: sip:707@192.168.X.XXX:5060;user=phone
    13:05:10.359 [MS210005] C:6.1:Answer provided. Connection(proxy mode):192.168.XX.XX:7024(7025)
    13:05:10.359 [MS210001] C:6.3:Answer received. RTP connection[unsecure]: 127.0.0.1:40618(40619)
    13:05:10.359 Remote SDP is set for legC:6.3
    13:05:10.343 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    13:05:10.343 [CM503002]: Call(6): Alerting sip:999@127.0.0.1:40600;rinstance=62c55bcabdc42122
    13:05:10.234 [CM503003]: Call(6): Call to sip:408@192.168.XX.XX has failed; Cause: 487 Request Cancelled; from IP:192.168.XX.XXX:5060
    13:05:10.234 [CM503025]: Call(6): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=62c55bcabdc42122]
    13:05:10.234 [MS210004] C:6.3:Offer provided. Connection(proxy mode): 127.0.0.1:7028(7029)
    13:05:10.171 [CM503005]: Call(6): Forwarding: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=62c55bcabdc42122]
    13:05:00.265 [CM505001]: Ext.408: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_331-UA/3.3.1.0933] PBX contact: [sip:408@192.168.XX.XX:5060]
    13:05:00.265 [CM503002]: Call(6): Alerting sip:408@192.168.XX.XXX:5060
    13:05:00.156 [CM503025]: Call(6): Calling Ext:Ext.408@[Dev:sip:408@192.168.XX.XXX:5060]
    13:05:00.156 [MS210006] C:6.2:Offer provided. Connection(by pass mode): 192.168.X.XXX:9004(9005)
    13:05:00.109 [CM503004]: Call(6): Route 1: Ext:Ext.408@[Dev:sip:408@192.168.XX.XXX:5060]
    13:05:00.109 [MS210000] C:6.1:Offer received. RTP connection: 192.168.X.XXX:9004(9005)
    13:05:00.109 [CM503010]: Making route(s) to <sip:408@75.145.XXX.XX;user=phone>
    13:05:00.109 Remote SDP is set for legC:6.1
    13:05:00.109 [CM505001]: Ext.707: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP1450 1.0.1.66] PBX contact: [sip:707@192.168.XX.XX:5060]
    13:05:00.109 [CM503001]: Call(6): Incoming call from Ext.707 to <sip:408@75.145.XXX.XX;user=phone>
    13:05:00.093 [CM500002]: Info on incoming INVITE:
    INVITE sip:408@75.145.XXX.XX;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.X.XXX:5060;branch=z9hG4bK760801006;rport=5060;received=67.186.XXX.XXX
    Max-Forwards: 70
    Contact: "IXXX SXXX"<sip:707@192.168.X.XXX:5060;user=phone>
    To: <sip:408@75.145.XXX.XX;user=phone>
    From: "Imran Siddiqui"<sip:707@75.145.XXX.XX;user=phone>;tag=1011917716
    Call-ID: 1377627333-5060-27@BJC.BGI.B.BBE
    CSeq: 21 INVITE
    Accept: application/sdp, application/dtmf-relay
    Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
    Proxy-Authorization: Digest username="707",realm="3CXPhoneSystem",nonce="414d535c0444d8cb01:f2457f77057aa5a7ed9b08b60e0abde6",uri="sip:408@75.145.XXX.XX;user=phone",response="eae043b96dc410d4cb16adf053edf459",algorithm=MD5
    Supported: replaces, path, timer
    User-Agent: Grandstream GXP1450 1.0.1.66
    Privacy: none
    P-Preferred-Identity: "IXXX SXXX" <sip:707@75.145.XXX.XX;user=phone>
    Content-Length: 0
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Post the config of your firewall if you can...
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    Have you run the firewall checker ?
    You need to NAT public address of the router to the internal address of 3CX server for ports 5060 (UDP), 5090 (TCP & UDP) and 9000 - 9049 (UDP only).
    Regards
  4. hollyb
    Jul 30, 2011
    6
    Thanks for your help. Here is my current incoming services settings. These ports are forwarded to my phone system. The firewall checker comes up with no errors and everything passes.
  5. hollyb
    Jul 30, 2011
    6
    Today we were able to get the external extension to work if we use the 3CX SIP Proxy. However, since these people are telecomuters all they have onsite is their notebooks. Therefore, the phone will only work if their notebook is on.
  6. eagle2
    Apr 27, 2011
    1,083
    10
    I don't have experience with these routers, but why don't you try forwarding ports in 1:1 mode, i.e.
    internal 5060:5060 <=> public 5060:5060
    internal 5090:5090 <=> public 5090:5090
    internal 9000:9049 <=> public 9000:9049
    UDP or TCP correspondingly.
    Regards
  7. hollyb
    Jul 30, 2011
    6
    I am not sure what you mean by the 1:1. We don't block any outgoing ports.
  8. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    52
    I think what eagle2 meant is, why is your Client Port not equal to the Server Port? Make your Client and Server ports equal to each other.
    e.g. Row #1 - Protocol UDP - Client Port 5060:5060 - Server Port 5060:5060 and so one.
  9. eagle2
    Apr 27, 2011
    1,083
    10
    Exactly what I meant,
    I'm afraid Hollyb is losing packets in NAT the way it is configured. A Wireshark capture could prove it.
    This should be a type of 'destination' NAT public address to private one without port translation.
    'Source' NAT is not defined in that table and should implement also port mapping / translation (it should be OK).
    Regards
  10. hollyb
    Jul 30, 2011
    6
    The table that I provided is a list of all the ports that we configured for use with 3CX.
    We also have an inbound policy that points the public ip to the private ip of the #CX server using the ports in that grid.
    I tried changing the client ports to match but that does not help either.
  11. hollyb
    Jul 30, 2011
    6
    Here is a capture of wireshark during the time a call was made by an external extension to an internal extension.
    I have also included the Server Activity log from that time frame as well.
    19:08:17.671 Currently active calls [none]
    19:07:47.593 Currently active calls [none]
    19:07:40.796 [MS105000] C:5.1: No RTP packets were received:remoteAddr=192.168.1.111:9004,extAddr=0.0.0.0:0,localAddr=192.168.48.70:7022
    19:07:18.562 [CM503008]: Call(5): Call is terminated
    19:07:18.546 [CM503021]: Call(5): ACK is not received
    19:07:17.562 Currently active calls - 1: [5]
    19:06:58.906 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.48.70:5060
    19:06:47.546 Currently active calls - 1: [5]
    19:06:46.500 [CM503007]: Call(5): Device joined: sip:999@127.0.0.1:40600;rinstance=aece7bff687e2640
    19:06:46.500 [CM503007]: Call(5): Device joined: sip:703@192.168.1.111:5060;user=phone
    19:06:46.500 [MS210005] C:5.1:Answer provided. Connection(proxy mode):192.168.48.70:7022(7023)
    19:06:46.500 [MS210001] C:5.3:Answer received. RTP connection[unsecure]: 127.0.0.1:40618(40619)
    19:06:46.468 Remote SDP is set for legC:5.3
    19:06:46.468 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    19:06:46.468 [CM503002]: Call(5): Alerting sip:999@127.0.0.1:40600;rinstance=aece7bff687e2640
    19:06:46.375 [CM503003]: Call(5): Call to sip:408@192.168.48.70 has failed; Cause: 487 Request Cancelled; from IP:192.168.48.233:5060
    19:06:46.328 [CM503025]: Call(5): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=aece7bff687e2640]
    19:06:46.328 [MS210004] C:5.3:Offer provided. Connection(proxy mode): 127.0.0.1:7026(7027)
    19:06:46.281 [CM503005]: Call(5): Forwarding: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=aece7bff687e2640]
    19:06:36.375 [CM505001]: Ext.408: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_331-UA/3.3.1.0933] PBX contact: [sip:408@192.168.48.70:5060]
    19:06:36.359 [CM503002]: Call(5): Alerting sip:408@192.168.48.233:5060
    19:06:36.265 [CM503025]: Call(5): Calling Ext:Ext.408@[Dev:sip:408@192.168.48.233:5060]
    19:06:36.265 [MS210006] C:5.2:Offer provided. Connection(by pass mode): 192.168.1.111:9004(9005)
    19:06:36.218 [MS210000] C:5.1:Offer received. RTP connection: 192.168.1.111:9004(9005)
    19:06:36.218 [CM503004]: Call(5): Route 1: Ext:Ext.408@[Dev:sip:408@192.168.48.233:5060]
    19:06:36.218 [CM503010]: Making route(s) to <sip:408@75.145.173.12;user=phone>
    19:06:36.218 Remote SDP is set for legC:5.1
    19:06:36.218 [CM505001]: Ext.703: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP1450 1.0.1.66] PBX contact: [sip:703@192.168.48.70:5060]
    19:06:36.218 [CM503001]: Call(5): Incoming call from Ext.703 to <sip:408@75.145.173.12;user=phone>
    19:06:36.203 [CM500002]: Info on incoming INVITE:
    INVITE sip:408@75.145.173.12;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.111:5060;branch=z9hG4bK917037307;rport=5060;received=67.186.100.108
    Max-Forwards: 70
    Contact: "Joe Cernik"<sip:703@192.168.1.111:5060;user=phone>
    To: <sip:408@75.145.173.12;user=phone>
    From: "Joe Cernik"<sip:703@75.145.173.12;user=phone>;tag=1480280065
    Call-ID: 959306411-5060-198@BJC.BGI.B.BBB
    CSeq: 31 INVITE
    Proxy-Authorization: Digest username="703",realm="3CXPhoneSystem",nonce="414d535c04467f0c04:a83e96bcf99d1facd13ba0b5ea6c7118",uri="sip:408@75.145.173.12;user=phone",response="b9696685179bf471e7685a8db31dd205",algorithm=MD5
    Privacy: none
    P-Preferred-Identity: "Joe XXXXX" <sip:703@75.145.173.12;user=phone>
    Content-Length: 0
    19:06:15.546 Currently active calls [none]
    19:05:45.531 Currently active calls [none]
    19:05:13.531 Currently active calls [none]
  12. eagle2
    Apr 27, 2011
    1,083
    10
    There is an issue also with external address of extension -- in the last post there is an address 0.0.0.0 which should not appear. This usually means the public address of remote extension is not resolved properly. Check in 'Phones' what is the registered address of remote extension - it should be a public one.
    Also changing NAT configuration (ports, etc.) may require rebooting the router, i.e. killing current connections.
    Try running wireshark and capturing the traffic. Also if this router support SIP ALG (or SIP NAT) try disabling it.
    Have you run the firewall checker on 3cx server ?
    Try also forcing 'PBX delivers audio' for remote extensions.
    Regards
  13. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Following procedure should fix this issue.
    Management console.
    page: Settings->Advanced
    Tab: Custom Parameters
    search for the parameter named ALLOWSOURCEASOUTBOUND.
    Check point: you should see that this parameter value is 0
    Change value to 1
    Press Apply.
    Ask remote user to reboot phone.
    if problem still persist please provide new log.
  14. jerry0503222
    Aug 3, 2011
    ____________________________________________
    microsoft office professional 2010,outlook 2010
