D-Link DIR-655
Discussion in '3CX Phone System - General' started by running, Sep 24, 2012.
  1. running
    Jun 24, 2011
    37
    Hello, running 3CX V11 SP1, I know a few people on here recommend the D-Link DIR-655, I plugged it in and immediately I could not register trunks with Callcentric, just wondering if people have settings suggestions, thanks. 3CX passes firewall test with forwarded ports 100% ok.
  2. wiltech
    Sep 27, 2012
    I have the same setup (D-Link DIR-655, 3CX V11 SP1, and Callcentric). No special settings required with the DIR-655. It automatically port forwards and has "smart" packet distribution. The factory settings should be good enough. I would check two thing: 1) make sure you set up the Callcentric VoIP provider correctly and 2) make sure you internet connection jives with your router setting (i.e. Dynamic IP for standard cable internet or PPPOE for DSL).
    Also, once you get it working, if you don't set up static IP addresses for your machines, use the DHCP reservation list (setup>network settings). Consistently having the same IP addresses will save you grief in the future.
    And update the firmware of the router if you haven't already.
  3. running
    Jun 24, 2011
    37
    I did that and it worked, if I disable SIP ALG it fails to register, very strange.
  4. running
    Jun 24, 2011
    37
    I also heard we should turn Dynamic Fragmentation off?
