d-Link
Discussion in '3CX Phone System - General' started by woodduck, Jul 30, 2007.
  1. woodduck
    Jun 15, 2007
    6
    I'm confused. I am trying to set up a system for my SOHO, and want to use the existing PSTN lines (2).
    Can I use a D-Link DVG-1120M as a Gateway to connect to one of the PSTN lines.
    I asked before about using this, and was told that it would work.
    Is the Line Port actually an FXO port?? If so does anyone have an example of setting up the system to use it.
    Thanks for putting up with me
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Your particular device isn't on the tested and approved list but if you take a look at the setups for a few of them I'm sure you can get an easy feel for the setup you need for your device:
    http://www.3cx.com/support/voip-gateways.html
    I tried to find info on your device but dlink said it was discontinued and I wasn't able to find anything usefull quickly.
    Hopefully someone else here will have some better configuration answers for you....
  3. Anonymous
    Anonymous Guest
    If you have a chance drop us a manual of the device, it was possibly me :oops: that said it would work so I might have a go at it to see if we can get it to work.
