Dail Codes
Discussion in '3CX Phone System - General' started by jasonhayes, May 14, 2012.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    9
    I'm having problems using the 3CX dial codes. nothing happens. I think it is our hand sets (which are hnad me downs) AVAYA 4610 SW. If I dial for example *9xx, nothing happnes. I know the codes are working as I replaced *9 with just 9 and it worked, however the 3CX tells you they must have * in front of every code. Can anyone help?
    Also what has happened to the forum this morning, I can find the Search box anywhere, I tried to search to see if anyone had asked this question before,
  2. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    I had a similar problem with some Linksys PAP2 adapters, these support "Vertical Service Activation Codes" which all start with a "*" so if a dial code that also existed in the adapter was used the adapter took the code rather than sending it to the PBX.
    For example if a PBX had a code *78 to access email this would work fine from say a polycom phone, however on a PAP2 this is the "Do Not Disturb Code" so dialed from a PAP2 you didn't get voice mail but put the phone into DND mode.
    I would guess that your phone uses special features "*" codes for certain functions so you either need to switch off these codes in the phone or change any that conflict with ones you want to use on the PBX.
