daisy chaining phones
Discussion in '3CX Phone System - General' started by ZenMasta, Jul 31, 2012.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    You know how many phones have a sw and pc port? Would it work to plug another phone into the pc port?
    I wanted to add a 2nd phone to a remote area of the office that doesn't have any extre lan jacks so I was thinking I might try this. Any known problems? I'm planning to try this with 2 spa504gs when they come on thursday.
    10,365
    227
    Should be no problem, the second Ethernet port is usually just a bridge, so it behaves like a switch with one port going to the device it is within, and the second appearing as a socket.
    I have daisy-chained a few SPA2102's rather than use a switch (LAN ports set to Bridge Mode). The only risk is that if one fails (or the power supply), so will all devices beyond it.
