Danish Voice Prompts Missing
Discussion in '3CX Phone System - General' started by easysoft, Nov 11, 2009.
  1. easysoft
    Mar 30, 2009
    5
    Hello I read in the thread
    http://www.3cx.com/forums/new-3cx-voice-prompts-10229.html
    That the Danish Voice Prompts should be available, but they don’t appear in my list over Voice prompts I am able to download.
    Are they not available for the this version on 3CX ?
    I am currently using version 8.0.9908
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    That's the Old Version 7 thread.
    I'll tag it with a V7 Sign so people dont get confused.
    At the moment ( 1AM ) i dont remember if we had Danish Prompts for V8, i'll check it out tomorrow and let you know.
  3. easysoft
    Mar 30, 2009
    5
    Hello Leonidas
    Have you found out something more about the Danish Prompts for the Version 8 ?
    Since I now have 2 customers who might be interested switching to 3CX but is very important for them to have Danish Prompts.
    Have tried with the ones from Version 7, but are more files for the Version 8 so not all fines will be correct.
  4. LeonidasG
    Nov 19, 2008
    1,559
    118
    Correct, there are new prompts included in the new system.
    If you want a solution of your own for the moment what you can do is download the Standard English prompts and compare them with the old Danish files of V7 and listen and see which ones are missing, and you can record them yourself if you are in a hurry for prompts.
    We are constantly Updatning the V8 Prompts list, but creating them takes some time.
