Data bad shown with a spa504 and 3cx
Discussion in '3CX Phone System - General' started by equintana, Feb 22, 2011.
  1. equintana
    Dec 20, 2010
    57
    I have some spa 504 7.4.6 and 7.4.7 fimrware devices. All of them running with a 3cx software with a epygi quadro isdn gateway.
    When a customer calls us, this info is shown(exacly):
    customer´s number
    When I say "my own number"is the number of my company. Can I remove dispalying my own number and only show the calling number(customer´s number)?
    Regards
    10,368
    228
    What does the 3CX log show on an incoming call where this is occurring. Your own number is either coming from the gateway or your provider. I would suspect the former. Was your own number put in the gateway to identify the line that the incoming calls were coming in through?
  3. equintana
    Dec 20, 2010
    57
    The problem is not the data shown, the problem is the order.
    As a incoming number shows mine.
  4. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Yes but leejor asked for the logs to see where it is being added to know where to remove it.
  5. leejor
    10,368
    228
    Is this being used outside of North America? I ask that, because in North America, in general (if you subscribe to caller ID), a name is also sent along with a telephone number. 3CX is set up to display both the name and number. Outside North America, for the most part (there may be some exceptions), only a number is sent. This leaves the name field empty. Some gateways, seeing no name incoming, will fill that field with a name (number) datafilled in the gateway, and send it on to 3CX. Some users make use of this to indicate to the called extension, which line the incoming call came through on.
  6. equintana
    Dec 20, 2010
    57
    Yes,
    It´s used in Spain. I know this situation, adding caller but, what I´m saying is:
    -at the phone screen when, for example to phone me, is displayed the following:
    your number(from USA for example)
    The order show is mixed,changed how to invert this order.
