DATA BASE MS SQL (down)
Discussion in 'Call Flow Designer' started by ClercGA, Sep 24, 2017.
  1. ClercGA
    Sep 24, 2017
    5
    PABX is on Linux.
    MS SQL is installed on windows 10.
    How do I know if MS SQL is down ?
    Currently the call ends immediately if MS SQL is down. If not everything works well.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,351
    108
    Hi @ClercGA,
    When you have any issue running your CFD app, for example if the database is down, the Main Flow will stop executing and the Error Handler flow will take over. In this flow you can play an error message for example, so the caller has some information about the issue.
    Kind regards.
    Ernesto.
  3. ClercGA
    Sep 24, 2017
    5
    Ernesto,
    Thank you very much for your answer.
    Kind regards/GA
