- Joined
- Sep 7, 2007
- Messages
- 12
- Reaction score
- 0
Hello Group,
here is the setup
3CX running on windows 2003 server in data center public ip address.
dns on windows 2000 server set to resolve to sip.pbtoolkit.com
i tried adding the extra server locaton dns entry but could not enter the periods so it looks like _sip_upd and i left off the pbtoolkit.com since i could not enter the . ( i had the same troulbe with or with out hte dns entries and just using the ip address of the 3cx server)
I have 3 remote office extensions
all 3 extensions are registerd.
08:57:32.250 StratInOut:nHangUp [CM104007] Call(6): Call from Ext.5502 to 5501 has been terminated by Ext.5502; cause: CANCEL; from IP:70.58.103.44
08:57:16.656 CallConf:nIncoming [CM103002] Call(6): Incoming call from 5502 (Ext.5502) to sip:[email protected]
when calling from 5502 to 5501 here is the logs
the phone 5501 does not ring, same thing from any extension to any other.
i do not have any voip gateways set up yet just trying to get the basic ext to ext wroking first.
i have tried it with the remote extension checked and unchecked same results. i am not really sure what the remote extensopn check box does.
using polycom ip301 on 2 exts and linksys spa2102 on the 3rd.
all were working fine with junctionnetworks.com virtual pbx system.
What could I be doing wrong?
Rhett
here is the setup
Rhett
