Database access through API
Discussion in '3CX Phone System - General' started by luciancr, Mar 9, 2015.
  1. luciancr
    Mar 6, 2015
    I am trying to figure out how to access an SQL Server DB from one of the 3CX APIs. I suppose this should be possible with the Call Control API. I have seen that this is possible through VAD, but I cannot figure out how to do this via the API. Is this feature not exposed through the API ?
    What I am actually trying to achieve is to configure a Digital receptionist to write to a SQL Server DB when caller presses 1 or 2.
    Thank you.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,405
    274
    What language are you writing in? I think the APi's are in C#?
    Are you using Visual Studio?
    What SQL DB are you trying to connect to? Oracle? MSSQL? MySQL? Other?
    Each of these have different connection strings required to connect to from VS.
    But this would have nothing to do with the API's.
