Database component dynamic SQL
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Jan 14, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    It would be great if the database component could take a variable in the SQL field. Then SQL could be dynamically built.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Well, you can use a parameter for that. Parameters values are put into the SQL statement, so you could have your SQL statement like this:
    {0}
    And then enter a single parameter pointing to a variable containing the string that you need.
    Regards,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Oh right, that makes sense. Didn't think of that.
