Database Component
Discussion in 'CRM / Helpdesk / App Integration' started by No-body, Dec 27, 2011.
  1. No-body
    Aug 19, 2010
    13
    Is there any way to connect to a .CSV file via the ODBC Database Access Component? I like to query the file instead of a regular DB.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    You can connect to any data source using ODBC. Not sure what query language you would have to use, but maybe it's possible. Please, try it and share with us your experience.
    Thanks,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    After you get your DSN connections in your ODBC correct, this type of sql should work.
    "select name, salary from employee.csv e, salary.csv s where e.id=s.id"
